Ye olde dominion | About half the time I cut the tractor off and thereby cut power to the entire precision planting system a red light comes on the 2020 display. When this happens it takes anywhere from an hour to 3 hours before the light goes out. Until the light goes out, the display will not boot up no matter what I try. I unplug the Ethernet cable from the back of the unit to ensure it doesn’t continue to pull power and I’m assuming there’s some kind of back up battery power inside the display itself because the light remains on after unplugging. Once the light goes off I can plug display back in and fire up the tractor and everything works fine. Anyone run into this issue? Thanks for any feedback. | |
