Southeast Colorado | DT87 - 5/16/2023 03:36
Question:said if we swath or spray we have to leave 10’ strip every 40 acres. Can you plant through that strip?
No, you can't plant through or damage that strip. It will be adjusted later...........or you can actually harvest it to get a true bpa number. If you're happy with your adjusters bpa number..........you don't need to leave the strips. A higher number is better for your APH, but obviously will be subtracted from your indemnity check. |
