Fontanelle, IA | If it were row unit #4, you would end up with a 4 good rows, skip, then 6 good rows, then skip row, then 4 good rows.
To me,it looks as though your marker is off so you plant wide 1 pass and then run 1 outer row over itself from the previous pass.
Edit. You might find a 1 row planter unit to pull behind a 4-wheeler if you had any seed corn production sites close by to borrow or rent. I would find a way to replant
Edited by Baby Robin 5/15/2023 20:00
