roaming | Breamer97 - 5/7/2023 11:19
Hello all. I have a pro 700 on a air seeder. Will be running two fertilizer prescriptions. Can someone help me with the proper folder structure to put multiple fields on a thumbdrive? I am more concerned with the task data way of doing but .cn1 info will be helpful as well. Thanks much.
you will have a TaskData folder in the root of the USB stick, alongside your CN1 folder. Do NOT nest either one inside the other. They both must be "side by side" on the root of the flash drive. If you're using Shapefiles at all, you'll also have a "shapefile" folder in the root.
The TaskData folder that is exported from your desktop mapping application should already be properly formatted with all the growers, farms, fields, prescriptions, etc, and ready to go onto the USB stick. |
