SE ND | I'm running a 12 row JD 1770NT with ground drive. No CCS. CT-350 for monitoring so no SeedStar on the planter. I'm planning to install an Ag Leader STMM and I have 2 questions. Where is an easy place to install the implement switch? I'm overthinking it. Pictures would be great! Ag Leader says to install STMM on the planter close to the main valve block. Can I install it in the cab at the end of the CT-350 harness instead of opening the harness at the hydraulic valves?
TIA | |
