Posted 5/1/2023 22:08 (#10212212 - in reply to #10212171) Subject: RE: JD rate controller not maintaining rate when sections shut off
I'll take a look at upping the cal number on the valve for the response time. Looks like I can up it quite a bit.
Can you explain the second & third questions? There is a manual ball valve for the agitation/bypass. Also the line back to the tank from the section valves on the boom. Are you referring to the agitation valve? I didn't change this at all from when I was using the Raven 450.
