NE South Dakota Clark, SD | First question what level of correction are you running. Centerpoint RTX or RTK. Always start with the implement out of the ground. Snap a new AB line and let it drive on line for a ways. Turn around in let it steer on the same line again. Are you driving in the same tracks? If yes, you have an implement draft problem. If not, adjust offset half the distance the opposite way. Snap a new line, rinse wash repeat until correct. Once tractor is correct drop the implement and do the same. |
