Posted 5/1/2023 10:31 (#10211252 - in reply to #10204673) Subject: RE: Climate field view with CNH 1050 display
Quebec, Canada
Here is a pin out diagram of the J1939 port that the Drive normally plugs into. You want to get CAN Hi (yellow), CAN Lo (green), ground (black), and 12V power (red) to the drive pins from that 6 pin connecter on the back of your XCN-1050. You will also need Universal Terminal unlocked and outputting CAN GPS .
