Thumb of Michigan | wildcat1000 - 12/6/2022 17:04
+1
Generally . If you enroll in part B, and get the plan G, you are in a mainstream. You are generally accepted at all medical facilities regardless of health.
If you have an advantage plan, check carefully how you are covered when you are not in the insurance company’s network.
+2, run from advantage plans. I don't think you will find an independent agent that's been in business a long time that would recommend a plan C (advantage plan). |
