Posted 11/24/2022 12:48 (#9947916 - in reply to #9947490) Subject: RE: M farmall losing power
West Central IA
How long has it been since you went through the carb? That would be next after you determine fuel flow is good. It could be as simple as opening up the power screw if there is some crud blocking part of that circuit.
