Search Forums | Classifieds (1) | Skins | Language
Massey 8450 tortoise/hare shifting issues
onion farmer
Posted 9/22/2022 22:33 (#9856935 - in reply to #9856876)
Subject: RE: Massey 8450 tortoise/hare shifting issues
southeast Washington
Most likely the is a plastic part that tells the tractor what range it is in. If dirt packs in there it will have trouble shifting. It sounds like you cleaned it hopefully very good where that shifter is in the left side of the tractor. Sometimes the part breaks so it will not tell the tractor the correct range. To fix move the fuel tank out some and you can get in there and replace it. If you shift it manually and it reads correct and drive in both ranges that is not the problem.
