We export files from our system to JD as Map Layers - you can then see them under Your Field in Field Analyzer. GeoPard adds to the Ops center Planting, As-applied, Soil, Topography, Nitrogen Use Efficiency and other maps. When you import Rx shp in Ops center - they don't split it to spraying / planting - you have just "Prescription".
