Search Forums | Classifieds (150) | Skins | Language
GRC on AG Chem 1803--Control Valve Cal suggestions?
Matthew2158
Posted 9/14/2022 07:44 (#9843654)
Subject: GRC on AG Chem 1803--Control Valve Cal suggestions?
North Carolina
Long story, but I'm correcting a GRC-liquid install on an 1803 Ag Chem sprayer done by another dealer. These machines use a hydraulic servo valve (like the chain conveyor hydraulic valve on a New Leader spreader bed) to turn a hydraulic PTO which spins the solution pump. I am using this valve as the control valve b/c this is the only feasible way to vary the spray output rate. Through trial and error and consulting the RC manual I think I've found that Fast-Close is the appropriate valve type in the GRC.
If anyone else has this type of setup, do you mind sharing what calibration number you used?
TIA,
Matthew
Edited by Matthew2158 9/14/2022 07:46
(1803 servo valve (full).jpg)
Attachments GRC control valve cal numbers.pdf (295KB - 144 downloads)
Attachments 1803 servo valve (full).jpg (24KB - 112 downloads)
