Quebec, Canada | I cannot help much with the harness part numbers, but your Case dealer should be able to help you out. If they can't then try reaching out to AgExpress.
For the memory card you want to go with a quality brand, not the cheapest options off amazon or ebay. I think there might be a maximum size that the Pro600 can handle, so it might be worth overpaying at the Case dealership to make sure you get a card that will work.
Once you get the maps saved to the card you can use something like SMS to view/edit the yield maps. SMS has a free trial so you can try that out for 30 days. I know that FieldView can import the yield maps and let you do yield analysis, JD Operation center might be able to load them too, but I'm not sure about that platform. | |
