East Central Indiana | Machine stopped the other day while using it. The seat belt light popped up and locked hydraulics out. Put in a new seat switch, but not the problem. Checked fuses and relays and about the only thing it can be is the a post. Just got our new Instrument cluster in this morning, and now it won't even start. Question is do these need to be programmed to our machine. None of the gauges register or anything when you turn the key on. Thanks | |
