What grain cart
Larry_minn
Posted 8/6/2022 15:49 (#9783472 - in reply to #9782856)
Subject: RE: What grain cart
Well you know front, front corner unload augers are easier to use. I got a 610 Brendt. I used on NH TS 110 but only filled it from bin, to load semi. Dry corn…. Under 10mph in yard it was fine. At speed in field not full it was fine.
So I would consider larger. I was aiming for 450 bu. Glad I went bigger. I am ok with side unload. But if others drive it they might like front, corner augers.
A larger cart, not filled will have larger tires should ride over softer ground then smaller cart/wheels loaded with same bushels.
