Search Forums | Classifieds (17) | Skins | Language
8530 Water Pump
wcbook
Posted 8/5/2022 18:41 (#9782246)
Subject: 8530 Water Pump
Hello all.
Working on a John Deere 8530, replacing water pump. We have the driven fan drive that slides into the water pump housing and is held in by a single snap ring.
To not fight the snap ring in a tight spot could I just remove the bolts holding on the water pump housing on and pull both the water pump housing and the driven section of the fan drive out at the same time? We are also replacing the driven section of the fan drive so reassembly isn't a problem.
Any input or thoughts is appreciated.
Thanks!
