Posted 8/3/2022 16:04 (#9778905 - in reply to #9778660) Subject: RE: What do I need for elevation survey?
Cedar Rapids, Iowa
If you need a serial-to-Bluetooth adapter, I'd recommend either a DigiFarm Beacon or Parani SD1000. You'll probably have to make a cable for either of those options. I'm not sure the Parani will tolerate 20 volts though - they're alright with 12 volts.
