Near Intersection of I-35 & I-90 Southern Mn. | As others have stated you either have an Integra or the InCommand 1200. The Integra uses the same connector as the older displays such as the Insight. The InCommand being newer uses a different connector. There is an adapter to allow an InCommand 1200 to be used with an older display cable as I use one in my sprayer and combine but this would be of no help in your situation. |
