West Central Iowa | I am using an AgLeader Insight, and a Trimble 252 on WASS for yield mapping and I am wondering if I need to update the WASS satellite on the 252. I pulled it out of the shed the other day and powered up the Insight and checked it a 1/2 hour later and the display said DGPS which makes me think it must of been finding enough satellites for DGPS. If it matters, I am pretty sure the 252 has V3.71 firmware as I updated it 2019 when I was going to use it for AutoPilot, but switched to a 372 instead. I did have the 252 working for IOWA CORS RTK before I swapped it out for the 372.
I have the cable and a laptop I can connect to the 252 if I need to change settings.
Thanks! | |
