Posted 7/2/2022 22:33 (#9731321 - in reply to #9731289) Subject: RE: pull type brush cutter
Wisconsin
Not that big a deal. it will slightly increase the wear on the u joint bearings, and the accelleration/deceleration of the center section, but it won't affect the gear box.
If you're worried, measure the angle and see what the max angle for the u joints is recommended.
