WI | I got reckless and added more than I should have all together in the sprayer without jar testing first:
https://youtube.com/shorts/28yrLqjL0bA?feature=share
https://youtube.com/shorts/r27z9zZs_cI?feature=share
75 lbs dry Manganese sulfate
51 lbs Dry AMS
25 lbs dry copper sulfate
20 lbs dry Solubor
60 gallons 5-15-15
~1 gallon chelated iron from a 2.5 jug
~1 gallon of Brant smart Quattro from a 2.5 jug
~1 gallon of Brandt B-Mo from a 2.5
~1 gallon Brant copper from a 2.5
~575 gallons of water (had been in tender tank 1 day so not COLD)
My main goal was to apply the Manganese in a 650 gallon mix over 65 acres at 10GPA and everything else was just extra partial odds and ends that I thought I could just throw in to use it up. It all went in individually through an inductor with water.
I’m guessing the Solubor and copper didn’t play nice. Of the resulting ~650 gallon mix, I got about 250 gallons of dark blue water to separate back off to the top and 400 gallons of melted whitish milkshake consistency suspension of small solid particles. It WILL NOT go though a screen. It will plug a 2” strainer in seconds with white gel. But it will pump through a 2” pump no problem, and I pumped it back out of the sprayer and easily rinsed it out of the tank.
Any idea what chemistry I created? Or if it’s still safe to spread out on a field when the time allows?
(5583D93D-F475-4FD9-BD5A-ED67D5C8957B (full).jpeg)
(73216E9D-7678-4754-B518-14D5EBA54128 (full).jpeg)
(1D9F96A9-01AB-444E-BD87-7F9108044597 (full).jpeg)
Attachments ---------------- 5583D93D-F475-4FD9-BD5A-ED67D5C8957B (full).jpeg (102KB - 292 downloads) 73216E9D-7678-4754-B518-14D5EBA54128 (full).jpeg (130KB - 290 downloads) 1D9F96A9-01AB-444E-BD87-7F9108044597 (full).jpeg (60KB - 289 downloads)
