Alberta | Is your ez 500 released so it is turning the steering wheel when the little wheel turns? Did you change your setting for offline engagement? Also before you change equipment, make sure you save your configuration setting so you can load it the next time you go back to the planter, sprayer etc. I always just name my config data files with the tractor and date. Eg "mx110jd7000may22" so as when you go back to that implement you can just load the config data file. and I also always save before I load a new one. It is always easier to delete than start over.
