Posted 6/29/2022 07:36 (#9726178 - in reply to #9726118) Subject: RE: Ford TW to 8830 deluxe hydraulic remote hydraulic pipes failure HELP...
Mount Vernon, WA
I don't know what they are either, however if it was me I'd get rid of the pipes all together and replace them with hoses. You should be able to install o-ring boss fittings directly into the valves and then adapt to whatever ends you'd like to put on the hose, either JIC or ORFS.
