| Yes, Ag Express makes a cable to connect everything together and power it up. I use the "straight" function if I want to maker and A+B or sometimes I do a curve. I find the curves recorded with the 4 wheeler end up getting too jerky when I come back with the tractor....so, now I use "curve" and only record a few points along the path (pause recording in between) when I have a border that isn't straight.
I record the exact edge of the field, then load it into SMS and shift it the appropriate amount for each implement. For example -- I record the exact edge of the field, the use SMS to shift the line 20' to then use with my 40' planter.
The implement width doesn't really matter since the A and B points determine the original line to which all of your other passes are generated. The pro700 will re-calculate when you change implements. | |
