Leesburg, Ohio | Those of you who said the leaking drain plugs on the pump housing indicated the housing is probably worn out, were right.
After checking Monday morning in daylight, I could see that there was only about one thread left where the drain plugs go in the pump housing.
Deere had none available, but our local Agrochem dealer had a new pump/motor assembly on the shelf (Deere uses a Hypro pump), at about 2/3 the price of Deere.
Had to adapt the hydraulic return line fitting to fit the new pump motor, otherwise all identical.
Thanks for the tips! | |
