Posted 6/26/2022 15:05 (#9722199 - in reply to #9722123) Subject: RE: Suggestions on how to remove broken Stud bolt on JD 1770NT
West Central Indiana
I always take the stud on the opposite side apart so I can work from it on the backside with a drill/easy out if need be.
And I heat the broken stud with a torch before I attempt to start twisting the easy out or left hand drill bit depending if it is right hand or left hand thread.
