| Just finished flushing tank and booms to switch product, pump worked perfect. Filled tank, went to field and now have no pressure. I can hear and feel the Hydraulic motor kick in and run, and it gets warm, but nothing at the pump.
Do you suppose the pump failed just now or am i missing something. I've tried adjusting pressure with switch, shut machine off. The pressure Gauge must work because I can see there's no pressure in the hoses to the booms.
Thanks for any insight.
