Posted 6/26/2022 07:48 (#9721570 - in reply to #9721214) Subject: RE: 688 parts diagram
The spring is held on by a hollow bolt. Into the end of the hollow bolt is a 90 degree swivel fitting and on the end of the swivel fitting is a compression fitting. Make sure the swivel fitting still swivels freely. Other wise all you should need is a compression fitting unless the line was ripped so it no longer reaches the swivel fitting.
