West Central Iowa | The most common sized MVE shipper is a 4/2V. That means it is a 4 liter vessel, and has a vapor holding time of 2 weeks when appropriately charged. That means after liquid is no longer visible, it should remain cold for two weeks. Seldom do companies ship traditional (wet) tanks as there us a significantly higher cost for shipping those wet vessels. My guess is you have a vapor shipper that had a little liquid left in the bottom and it should easily hold long enough for you to get things figured out. Posting the model on the side of the shipper would help us give you better advice. | |
