Posted 6/25/2022 05:46 (#9720036 - in reply to #9719746) Subject: RE: Freightliner cascadia clutch issue
East Central wisconsin
I find it much easier to bleed the clutch circuit, by pumping oil up from the bottom. Can use a clean oil can as a pump. Attach a hose between oil can and bleed screw on slave cylinder. Then open bleed screw and pump oil up the hill. Chasing the air bubbles up and out. Good luck.
