North Dakota | My rate on the 4600 will jump all around after it sits for a day or over night had it happen after I ran out of spray but it did it again with 100 gallon left after sitting half a day!! If I turn the aim from auto to manual it will hold right at my rate and maybe just drop a few psi! If I run it in manual for a few acres then switch back to auto it will find the rate and work fine after that the rest of the day! Was told it most likely is the box underneath and should switch it over to the new evo system?
Anyone ever delt with this scenario?
Thank you | |
