Quebec, Canada | You can buy just the Drive on its own (just comes with the owner’s manual/ warranty info) or pay a bit more for the Drive starter kit which comes with the Drive, iPad mount, USB charging cable and high quality cigarette outlet charger (the cheap ones that you find at gas stations don’t provide enough power to actual charge an iPad while in use, they just slow down how fast your iPad battery drains).
Most John Deere machines don’t need any kind of CANBUS adapters, the Drive just plugs into the diagnostic port. On Deere combines the diagnostic port tends to be by the driver’s right foot, in the corner behind the driver’s right shoulder, or hidden under the cup holder. AgExpress makes a bunch of FieldView Drive adapter cables for setups that don’t run through the vehicle’s CANBUS. Things like Trimble autosteer, or a Raven Viper Pro retrofit running a sprayer. | |
