| https://www.cambridge.org/core/journals/weed-technology/article/comp...
Here’s one to get you started.
Dose response curves and R/S values are much harder to do PRE.
Most work is done POST because it’s what we can see.
However evidence does exist that populations resistant POST will have some level or sensitivity shift towards tolerance level.
It’s basic biomass vs dose. PRE has advantage because of low biomass to high dose. But when that dose fades just alittle the resistant has enough to right thru. Thus those populations break sooner.
Edited by 9mm 6/19/2022 18:00
