South Central Illinois | Incredibly dry now. Wanting to set the depth on the drill. Preferably in the shop. 7 notches on the depth adjustment. Currently on #6 It was a replant situation, going for moisture. Maybe 1-1/2” + deep. It was on #5 for the wheat. That was probably 1”+ deep. Should I go back to the wheat setting? How much does each notch charge the depth? I could go with #4, seems like this would be on the shallow side. Thinking, set it while it is in the shed. Going to need multiple inches of rain to make this work. I have seed for 180,000 population. Should be able to cut the straw and cover most of them up. Do I need more than 180,000? |
