Fruita CO | Red Paint - 6/14/2022 13:38
Not that long ago, the only way to move bulk diesel fuel was with a 5 gallon can. Yet somehow it was burned in large quantities on huge earthmoving jobs. Every bit moved with 5 gallon cans between the oil truck and the bulk tank.
Then came the hand actuated rocker pumps on the oil trucks, then engine driven pumps, then modern PTO units.
I’m sure plenty of folks were skeptical of those pumps. They were expensive, complex, etc. Why not just keep using the 5 gallon can?
Yet somehow everything worked out. Do you use a pump, or the can? Which one would you prefer?
That's a hell of a stretch right there...**** |
