Posted 6/12/2022 20:22 (#9702368 - in reply to #9702211) Subject: RE: Raven with Ag Leader??
NCIA - Worth County
Tedbear will know more details than me, but yes you can enter a minimum flow rate in the controller settings. You can also change the speed input from display gps to a manually entered speed to trick the system into opening and closing valves without moving.
