Ogallala,NE | Fingers77 - 6/2/2022 20:32
Not easily that I have ever found.
Farm Works is owned by Trimble and has sub par line management features.
SMS "used" to work marginally better, but I haven't used it in years.
I usually export them from fields to my AB line folder, then import in another field as needed.
If renaming, I export Field Data, rename fields as I want, then re import.
Renaming lines I just do individually in each field.
Tedious.
Maybe I'll try sms, it's what I use for everything else. I see trimble's farmer core and farmer pro claim to do guidance line management. Not sure what that means. |
