Eastern NE KS | Check the placement of the new shearhubs. I believe you have them out of time compared to their neighbor shear hub/turtle. I think you should move them one tooth at a time.
Your job is more difficult than mine last year where I had a bearing set to replace under just one turtle. Your machine may run well with one turtle installed but not when the last turtle is installed. When I was putting my Moco together, I could shift my shear hub 1 tooth left or right to try for proper placement. Failing that, you may want to jump 90 degrees on the shear hub to see if that changes the 'fit'. I could be mistaken but I think there is just one mounting of the shear hub that works even though it looks like there would be four.
Unfortunately, it's been 11 months since repaing my Moco. I could have false memories. | |
