Posted 5/31/2022 16:46 (#9684701 - in reply to #9684675) Subject: RE: Raven viper 4 changing directions
Butterfield, MN
I'm pretty sure that the SmarTrax node is what keeps track of the direction of travel. Do you get a pop-up stating that it's in reverse now? I wonder if that unit has the ability to track Glonass sats, that would make a difference if getting low sats by the tree lines are causing problems.
