What do you have it installed on?
Had similar issues with a Raven system with the smartrax md. Was installed in an International 3388 2+2. Everything was installed correctly however that tractor has the cab behind the articulation joint and it did not do what Raven expected an articulated tractor to do. To correct the issue had to move the node to the front half of the tractor (now mounted on the fuel tank) and moved the antenna forward 16 inches or so and centered over the pivot point. At that point things settled down and it steered like it was supposed to. Took the tech that came out awhile to figure out what was going on. I had played with it for a couple of days and had run out of ideas.
He said that when the node was expecting movement one way that what it was seeing was the exact opposite and the more it tried to correct things the worst it got until it would just shut down. He commented that was the first time he had run into that issue.
