Nebraska | Can you do this in the display? I've always been annoyed since I can't find a way to add a "Tank Mix Name"
The only option that comes up is "Custom" There is no "New" or "Add" option anywhere I can find. "Custom" is literally the only tank mix name I can find.
So no matter what I'm spraying the volume and area totals are just added to the same tank mix totals unless I zero it out.
Its the only JD display I use and its only in my sprayer, so I am quite unfamiliar with JD displays in general. I tried to do a search and only get directed to some JD Operations stuff which I don't use at all, and don't know if this is the only way. | |
