| WHAT MONITOR ARE YOU RUNNING????
For something like a FM750 or FMX, you need the "Field Data" files exported. They will be in the AGGPS>Data>(Grower)>(Farm)>(Field) folder once you put the thumb drive in the computer. For something older like an FMD, it should still be the same types of files.
No idea about the new monitors, but I bet it's either similar or the same.
3 types of each file. a .SHP, .SHX, and .DBF
SMS should know where to look and or allow you to choose where to look as you import the data. Each event will have a long lost of various file names it needs in the folder to make a complete map.
Copy ALL of the Field Data out to a thumb drive and SMS should find it in the folder hierarchy as it sits. | |
