Posted 5/22/2022 16:30 (#9671042 - in reply to #9670830) Subject: RE: 1990 speed source
NE CO
1990s are a special sort of PITA to get speed sources into. What kind of main greenstar harness are you using? Is there a single pin plug for radar or GPS? It needs to be on GPS in that is the case so the receiver will send simulated radar speed back into the display. Also try checking the box use radar as speed source in the performance monitor if it shows up there.
