Posted 5/22/2022 10:14 (#9670618 - in reply to #9670468) Subject: RE: Ag leader seed tube sensor constant alarm
The implement switch will stop your hydraulic drives. The intention is that if you shut off the Master or raise the planter so the implement switch changes, then the hyd drives will stop. We are happy with how our population portion and the clutch control module and section clutches work together.
