Central/Northeast Missouri | Running a John Deere 8400 tractor pulling a Kinze 16/31 2600. Ag leader incommand 1200 for steering and row clutches and seed monitoring.
The planter plants but the monitor does not recognize seed dropping, it does pick up speed and acres though.
The tractor battery has 14 volts
Seed clutches have 13.7 volts
Seed tube monitors are getting 8.5 volts.
Any ideas?
Thanks
Edit to add -
The 37 pin connector reads 8.5 volts as well, no pins read 12v
Edited by FarmGuy97 5/20/2022 20:14
