NW Iowa | I'm assuming that the 12 openers are offset 3.75 inches from center, so that means that you need to offset your globe 3.75 inches and your track spacing will remain 15 feet.
From the pictures I've found of a 750 drill, it looks like the front gang is offset to the right and the back gang is offset to the left. So to center the front gang, you will need to move the front gang over 3.75 inches to the left. This will now center your front gang. Currently, opener 6 is 3.75 inches to the left of center and opener 7 (on the front gang) is 11.25 inches to the right of center. By putting in a 3.75 inch offset on the globe, Opener number 6 will be 7.5 inches to the left of center and opener number 7 will be 7.5 inches to the right. By putting an offset in your globe measurement of 3.75 inches to the right i believe, this will drive your tractor to the left side of your guidance line and your drill will be centered on it. Clear as mud?????
Edited by butchie 5/20/2022 18:13
