Search Forums | Classifieds (12) | Skins | Language
trimble speed output to kpm2 update
tedbear
Posted 5/19/2022 06:53 (#9666206 - in reply to #9666087)
Subject: RE: trimble speed output to kpm2 update
Changing the output frequency in the Trimble will change the displayed speed. Changing the speed cal value in the KPM 2 is another way. The speed shown is a combination of both numbers so changing either will affect the displayed speed. Change one or the other by trial & error and check the results. You should soon see if the change is going in the correct direction. After trying a couple of different numbers you should be able to get the displayed speed on the KPM 2 to agree with the Trimble.
The above reply shows the owner's manual. I suggest you print this out for your future reference since it is handy.
Edited by tedbear 5/19/2022 06:56
