Posted 5/18/2022 13:34 (#9665440 - in reply to #9664680) Subject: RE: Updating my Raven Cruizer monitor
Butterfield, MN
Yeah, that should be the one to go to, and the SmarTrax controller would need to be replaced with a 3D node that would plug in place of the long box controller. As long as the long box software is at version 4.0 or higher, the hydraulics should all be compatible already. If there's a yaw sensor plugged in, you'd have to unplug that when switching over to 3D.
