Near Intersection of I-35 & I-90 Southern Mn. | Spincat - 5/17/2022 12:14
We are also running insight. Have you figured anything out yet? Ours will
paint, but auto steer doesn't work.
Yes, the painting part will still work but you have uncorrected GPS because it is trying to use the satellite that was broadcasting the WAAS correction signal in the past. Your Insight doesn't need correction to paint.
You will no longer have steering because steering requires the correction signal which you no longer have. If it did work without the correction signal you wouldn't be very happy because it would be all over the place.
You need to figure out what you are using for GPS and find out how to change the settings yourself or find someone who will change the settings for you.
Edited by tedbear 5/18/2022 02:22
